fdc107 »
https://forums.nicoclub.com/fdc107-u150667.html
Thu Jan 14, 2010 6:31 pm
1991 Nissan 300zx Twin TurboMy headlights and tail lights are out....only thing that works are the high beams. when i switch between high and low beams, the high beams stay lit. Is this a wiring issue or the headlight switch. I had this problem about two years ago and had the whole harness under the dash replaced and now its acting up again. I checked all the fuses and they are all fine but i read in another forum that might not be the case and I might have to replace the fuses too as well as relays. I will try the ecu diagnostics again and see if anything happens. So I have my whole dash apart trying to trace wires and all. I have an aftermarket radio with an amp, apexi avcd manual boost controller, and hks turbo timer 1. Could this be a problem with something not being properly grounded or do you think that my high beam switch is shot. This all started after I replaced my clutch/flywheel and transmission. RPS max street six puck sprung hub with rps segmented flywheel, jdm used transmission.I go to start my car and the starter spins but does not engage; yes it is a tt clutch, tt flywheel, and a tt transmission I think it is the solenoid and will probably just buy another one. I had to pop the clutch to get is started.... grabs like hell too! I replaced the battery cables as well, tried tapping the solenoid but still a no go. Also think i have a short somewhere because my battery goes dead more often than not and thats when i started retracing all these wires in the dash and in the center console. Sorry for the long post just posting everything i know. Any help is greatly appreciated! Thank You!!!
