What's funny is that this is the SAME EXACT file my friend showed me. And I bought them from DDM too! No help though because I didn't get the hi/low converter.djtorello wrote:try this, the link goes to a PDF file where detailed instructions for the H13 HID install.
https://www.ddmtuning.com/supp...v=0,1
THat's what I did for the driver side. it was a pain in the a** though. the thing was, I just ended up cutting the entire harness. it still didnt work when i tried turning on the low beams.Faja wrote:I think what you have to do is connect the high and low beams wires from factory harness together and then you connect that to the red wire of the HID kit.
Yeah, but I was hoping someone here would've known already tho, which why I went here first. I don't have a multimeter as well so that's a problem haha.Faja wrote:You'll have to figure out which one is the low beam wire and try to power the ballast with it. Disconnect all the wires and then use a multimeter, turn on your low beam and see which one of the wires has power. Do the same for the high beam and you' should be able to figure out the correct hookup.
