Headlight polish?
RS91
How do I polish my headlight on my 95 240sx? Those plastic cover do fade fast.... Pls help..
Thanks
GrubyFngaz
Car: 2001 Infiniti QX4
Hey. Everyone on here reccomends using finger nail polish remover. I have used it and it worked, not as good as I wanted it to, but it helps. That's the only suggestion that I have. Make sure not to get it on your paint though, or it will be screwed up. Good luck. Josh
NOOOOO!
Only thing you should use is a product called NOVUS plastic polish. You can buy it at aquarium stores (it's great for polishing acrylic aquariums). It comes in 3 stages, use the medium stage for headlight lenses - It will make them look brand new again - I use it on all my lenses AND the clear speedo lens. :D
No reason to use anything else when NOVUS works so perfectly.
Holisticbeatz
Novus plastic polish eh? How much does a jar of it run? Have you ever tired using a power buffer?
