s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Sat Oct 11, 2003 9:31 pm
what motor? ka24 you should be able to adjust valve lash to avoid relocating the cams(if that is what you were considering). sr20, im not sure if the hla's compensate for that much or not. only one way to find out(well two actually, there is always trial and error) pull them suckers and sqish 'em by hand(with mechanical leverage of some sort). i am leaning towards them not having enough room though. also you will have to adjust cam timing, but you prob already thought of that.
