ravera »
https://forums.nicoclub.com/ravera-u137799.html
Tue Oct 06, 2009 6:12 pm
Quick and dirty... Step 1. Remove disconnect batt (should be a quick no brainer there), Drain fluids.
Step 2. Remove spark plug wires, just get them out of the way, pull the cap and take the wires with them.
Step 3. Remove intake, take off fuel rail and set it to the side. If there is a mechanical fuel pump, take that off at this time.
Step 4. Remove exhaust, set it to the side, use a piece of rope or whatever to tie it up.
Step 5. Take off the valve cover.
Step 6. Ram the timing wedge down on the timing chain. Once you've done this, remove the big 22mm? Bolt from the top of the cam and take off the cam gear.
Step 7. Remove the 14 10mm allen head bolts and the Two 10mm bolts at the front of the timing cover. Don't forget those.
Step 8. Yank.
Repeat these steps in reverse for replacement procedure.
