ca240 »
https://forums.nicoclub.com/ca240-u9852.html
Wed Nov 05, 2003 4:24 am
dude it really shouldnt be this hard...it takes a little time and it sounds like you've spend alot more than just that...check your FSM and make extra positive you got all the bolts...i'm gonna tell you where all the bolts are just in case you dont have a FSM...pretend you're looking at the engine from the passenger side...on the top there is one bolt to the right of cyl 1. intake runner(cyl one is at front of car just so there's no confusion), there are two between runners 2 and 3, then one to the left of cyl 4.
now for the bottom....there's one to the very!! bottom right of the manifold, then there's one between cyl. 1 and 2, then there's one between cyl 3 and 4...those on the bottom are really long and pop out at the bottom of the little "tower?" things that hold on the fuel rail...you must not have got those off man...i think they're between the runners that they go between...get it?...and the one that's all the way to the right is hard to get at..use an adjustable wrench and take your time...hope that helps man...now go pull your head off
