Head Pull Opinions. Engine in/Trans out
zxFarside
Car: 94 300zx TT (sold)
03 Suburban 5.3
00 BMW 323
Long time, no post.
So I've got a 94TT with a blown head gasket.
I'm going to do the job with the engine in the car. I plan on dropping the tans, then remove the turbos from the bottom, to make the head pull less spaghetti, rather than pulling the heads with the turbos and DPs attached.
I'm not in the position to pull the motor, which would be ideal, but alas is not the case. I'm hoping with the trans out of the way it'll help in some.
If anyone can think of any technical road blocks with doing this, please share!
Thanks!
elecfus
do you fully understand what it means to do a plenum pull on a z32?
most owners go insane from attempting it.
if you havnt done it before, buy all the electrical connectors, fuel rail spacers, seals and hoses first. there are even o-rings in the pressure equalising tube running from the AIV.
zxFarside
03 Suburban 5.3
00 BMW 323
Yeah, I've done it a few times. I'm no stranger to the Z, or wrenching on cars. I'm fully capable to the job.
I'm just seeing if anyone had any thoughts on doing the job as I laid out. Without pulling the engine.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Pull the engine. If you plan to remove the trans you might as well pluck the engine out, it's not much work beyond what you've already planned, and it will make turbo removal so much easier it will likely take less time in total.
zxFarside
03 Suburban 5.3
00 BMW 323
That's what I figured. I had sold my hoist a few years back, because I figured I wouldn't be doing anymore stupid projects. Yet, here I am again.
So the new question is: Would the time/effort I'd be saving taking the engine out be worth buying another lift?
...I'm feeling the answer is yes. lol
everpresentnoob
Car: 1990 300zx Base. Manual and abused by previous owner....
When I pulled the motor from my trans am i made a hoist... pulled teh car onto my porch under my deck, popped on of the flooring boards out of the deck above and used a 4" cast iron pipe laid across teh supports. few wraps of chain around it adn then suspended Block and Tackle from that. plucked the motor out easily, pushed the car back out of the way and put the motor on a stand.
granted reinstallaton was a touch awkward, but I ended up putting the front wheels onto those little dollys and then I could adjust where the car was positioned sice the motor would only move up and down. Ghetto, but it worked.
zxFarside
03 Suburban 5.3
00 BMW 323
I unfortunately don't have a deck. If I did, I would consider that. haha
red coupe89
Car: 1991 Fairlady Z
2005 Nismo Frontier 6spd 4x4
2000 Honda shadow ACE 1200
ive pulled the heads with the turbos and dp attached. i wouldent suggest it but it can be done. have to stand on the sway bar and hold the ol back holds up :chuckle:
zxFarside
03 Suburban 5.3
00 BMW 323
That was my original plan, but I'm not wild about pulling all the mess out at once. I figured getting the trans out of the way I can get to stuff from the bottom to make pulling the head less cumbersome. I'm not just not wild about spending another 300 bucks on a hoist and stand again.
evildky
06 Nissan 350Z GT
Buy a used one on craigslist then sell it on craigslist when you are done, or find a friend willing to loan one out. Mine has been in rotation between friends for many years.
