im not really sure what this has to do with my thread but sounds cool... to the others... so you really think i should just get a stock one for now until im actually able to afford internals and ****?? my head gasket is definetly blown and is the cause of my problems i had awhile back where i thought it was my piston and ****.. so its a relief toknow its not that..float_6969 wrote:Well, just for S&G's, I decieded to turn up the boost to see how the car would act. So that you know what kind of abuse we're talking about, this is a .5mm bored CA18DET, with 9.5:1 compression forged pistons. Stock rods, copper sprayed felpro headgasket, ARP head studs, on a fresh rebuild. I cranked it up to 1 Bar (SR T25, so I didn't want to go much higher) and the car is fine. I did 3 full throttle, low RPM to redline runs, basically in a row w/o any problems whatsoever.
BTW, my car is stupid fast. I'm soooo gonna get killed with this thing. High comp + small turbo = crazy fast spool. Top end kinda fell off, and I don't think it held 1 Bar to redline. I was watching my intake temps and knock sensor more than anything. I definatly need a T28...
Get a stock headgasket and some fresh head bolts and leave it alone. If you must have a copper gasket, I have one for $160, but you will spend more $$$s trying to prep your motor to properly receive this copper gasket.nismo_chk wrote:
If you read it, I did that on a stock style head gasket.nismo_chk wrote: im not really sure what this has to do with my thread but sounds cool... to the others... so you really think i should just get a stock one for now until im actually able to afford internals and ****?? my head gasket is definetly blown and is the cause of my problems i had awhile back where i thought it was my piston and ****.. so its a relief toknow its not that..
O-ring your block? Oh, so you can blow pieces of pistons and rod through the bottom of the motor instead? lol. o-ringing is for people who are running like 30+psi with a fully built motor. Also, are you saying the stock CA gasket doesn't have the fire rings at the top of each cylinder? If your stock gasket didn't have that, it's probably because the seal was crap and they got burnt up. I've never seen ANY hg without fire rings.knightrider wrote:my car made plenty of runs on the dyno at 18 psi with the stock headgasket, then at the track i spun a bearing and siezed the motor DOH!!. hehe, oh well. i think the only thing i would do is o ring the block, the stock CA gasket doesnt have the o ring that nissan later implimented into the stock HG later on, it helps seal the gasket better. not sure if the felpro one has this or not.
Permatex makes it and it's called Copper Gasket Spray. It helps seal the gasket to both the head and the block.zero_gripS13 wrote:whats this copper spray u keep mentioning??? name some companys that make it aND WHAT ITS USED FOR PLEASE?
What type of clutch are you using? I'm interested to know, so that I can compile some data on the RWD engines. It's something about them that spooks me.knightrider wrote:my car made plenty of runs on the dyno at 18 psi with the stock headgasket, then at the track i spun a bearing and siezed the motor DOH!!. hehe, oh well. i think the only thing i would do is o ring the block, the stock CA gasket doesnt have the o ring that nissan later implimented into the stock HG later on, it helps seal the gasket better. not sure if the felpro one has this or not.
also i wouldnt run a copper HG unless you are planning to tear your motor down repeatedly.
obviously you dont know what i am talking about, if you cut open a SR20DET headgasket, or any relatively new HG, you will see a piece of wire inside the fire ring. this is a cheaper alternative to o-ringing the block while creating a better seal. the CA did not come with this. also, i agree that the stock HG is fine for most ppl, that have stock motors. however my engine is going to be built, and tuned by someone with 30+ yrs of expirence, hi comp and hi boost, i want the best seal i can get.c-rad wrote:O-ring your block? Oh, so you can blow pieces of pistons and rod through the bottom of the motor instead? lol. o-ringing is for people who are running like 30+psi with a fully built motor. Also, are you saying the stock CA gasket doesn't have the fire rings at the top of each cylinder? If your stock gasket didn't have that, it's probably because the seal was crap and they got burnt up. I've never seen ANY hg without fire rings.
Let me tell you something and this is not to upstage any member's preference as sideways danny has his, the stuff works as I actually have it on my NISMO metal headgasket that I've removed from time to time and removed the coating it had on it. We wouldn't steer you wrong ! I think our credentials around here speak for themselves. You're surrounded by 4 moderators who each have their own merits/accolades and a gang of knowledgeable members with some moving from other car company camps and bringing their experience with them to the CA side of the world.nismo_chk wrote:ok. so you bring up a good point.. can you back it up any further? b/c now i dont know what to do.. my bf and dad said the copper stuff sounds good and they agreed i should use it, but now you say this.. so please give more info if you can.. thanks!
the engine that i just seized was a totally stock slut-o-matic CA that i got for 400$my original CA that i got is being rebuilt now ahead of schedule because of the other one crapping out on me, forged 9.5:1 or 10:1 pistons, tomei metal HG, custom ground cams, custom intake plentum and custom SS321 manifold and full exhaust, disco potato, 460 injectors, s13 blacktop SR ecu custom tuned.sdtouge wrote:what compression knightrider?
I too used copper spray on my stock gasket and mating surfaces with new OEM headbolts. And 2+ years later of daily driven 10psi, no hiccups *crosses fingers*boost_boy wrote:I have over 9 years of working with the CA series motors and 16 years on Nissan products in general, so I'll say this again and you can take it for what it's worth, get you a stock headgasket, you can spray it with copper spray if you want to, but is not a big necessity (It certainly won't hurt it), get you some fresh stock headbolts and go boost till your little engine melts a piston or something to that effect.
