harness break?
AK
hi, e
I drive a 96 maxima (automatic), and it started stalling at a lower RPM
so I took my car to a dealer and they went on a diagnostic
I got the result that says
"VEH HAS A POSSIBLE HARNESS BREAK & SHOTED ECU$3400.00 IF JUST THE EGI HARNESS OR $4200.00 IF ECU IS NEEDED ALSO"
I wonder if I can replace the car harness cheaper than that
I don't think I need to replace ECU, but I heard replacing harness
would be very expensive.
1. How much would it cost (approx) if I just change the harness at a local body shop
2. Will it be OK to use a used harness on my car?
maxhopper
Car: 02 Maxima SE 6spd
The replacement of the harness will not be cheap regardless of who does the work.
Yes you can use a used harness.
I would recommend finding a used harness from http://www.car-parts.com and install it your self.
AK
thanks for your comment
hm...by the way, I can't find "harness" from the list
is harness called something else or it's just not on there?
also, I'll try to change it by myself, but I don't have any info yet
do you know any sites, or article that shows how-to-do stuff?
thank you.
maxhopper
It's listed under Wiring Harness. The way I would do it is to lay the new harness out over the existing one, and disconnect/reconnect one thing at a time.
