DougQ45 »
https://forums.nicoclub.com/dougq45-u513.html
Tue Jan 13, 2004 4:13 pm
Typically they are "keyed" and should not slide or wobble at all. If they do, you have big problems as the crankshaft is the part it is attached to. I would not drive the car for failure of the unit could really cause serious damage!! If you have a puller, you could remove and inspect, and re-assemble. Bolt is tight and torqued right????
