Now for the hard part, the wiring.You can do this a few different ways. Its probably easier to get a complete dash harness from a 240sx from the same year if possible. I only say this because you might want to be able to unplug everything at the firewall. Most of everything youll be doing is pretty splicing the 240 dash harness into the truck fuseblock. If your doing it this way you might want to get the cluster with as it will save you some wiring time. Also the speedo from the truck will not work with sr vss. You might have to change the vss to a KA vss anyhow to get speedo to work. It will work but will read wrong.
D21 Cluster Harness
Alternator charge : yellow/black
4x4 : yellow/black
Right flasher : grey/red
Lefr flasher: grey/blue
Speed sensor : red
Seatbelt: black/pink
Oil light: yellow/blue
Brake: brown/yellow
Watertemp: yellow/red
Fuel: yellow/purple
Fuel gauge: yellow/green
Speedometer ECU signal: white/blue
Winshield washer: white
High beam : red/yellow
Bulb check relay: black/yellow
Fuse 10A, ON/START : white/black
ABS:blue/red
Digital clock, 10A: red/green
Digital clock light: green/white
Lights: pink/black & pink/blue
Ground:black
Check engine: red
Tachometer: white
Unsued:
Purple
White
Green/brown
Blue/brown
Green/black
Green/yellow
Green/white
240sx cluster harness (there are 2 connectors, as you can see on a picture on the first page)
White connector :
Fuse 10A, acc/on : blue
Power 10A, on/start
Lights : red/blue & red/yellow
Clock: red/black
High beams: red/green
Fuel gauge: green
Flasher ground : black
Flashers : green/black & green/yellow
Blue, yellow/red & yellow/green are originally connectes to another plug and must stay connected
Unsued: yellow/black
Yellow/blue
Black connector:
High beams: pink/black
ECM: red
Parking break: yellow/purle
Alternator bulb check: white/red
Winshield washer: red/blue
Fuel gauge: red/black
Ceinture: red/white
Oil pressure: yellow/white
Seatbelts:yellow/green
Black: ground ??
Got this from one of my other forums hope this helps. This is only good the s13, but wires are mostly the same for the truck.If you go s14 wires will also be different. In that case Just pull up a FSM for whatever year truck and motor you are using
Finished product not tucked or pretty but functional for now and everything works.
