Hard Start, no power, Check eng lite:J30
fxgo
Hi,
Yesterday afterwork, I went to start my J30. I had a very hard time starting her. After a few tries it started, there was a strong gas smell and I notice white smoke, not gray, comming out the back.
The car had no power. It was like the car was running on 3 cylinders. I also notice the white smoke. I checked the muffler and I notice water on the tail pipe. I checked the oil and the radiator. There was no mixing of the fluids. I checked the air filter. I fulled up the gas tank and added dry gas.
After some time the check engine light came on, I drove it home.
About a month ago, I did some preventive maintance 113,000. I replaced
Both Oxgen sencorsPower Transister ModuleFuel FilterFuel PumpAll belts and hosesTrans fuild flush
My J30 has 115,000 miles. I has been running great up until know.
Any help would be greatly appreciated.
Regards,
fxgo
Q451990
I'd sure like to know what that Check Engine Light code is... My first guess would be the Mass Air Flow Sensor or it's connection, but I'm just not sure...
I'm sure our J30 gurus will come along shortly with better advice.
Heath
fxgo
Thanks for the quick reply, I will check the diag codes tonight. I drive my trunk today. I have a service manual. It looks like I have to take out the ECM and turn a switch to get the engine light to blink diag codes. I will let you know what they are.
Thanks again
Regards,
fxgo
Eswift
Car: should be obvious enough
sounds like a bad injector or FPR.
get the codes.
if it is an injector, you can check the electircal resistance of each injector to determine the bad one, or you can use a stethescope and check manually, however this will just show when the injector is dead.
more likely it is leaking, and still might be outside ohm range.
Eswift
unfortunatley, this is the time of year for injector failures...
fxgo
I didn't get a chance to remove the ECM to check the codes. I will get to it on Saturday and let you know what the codes are.
If it is the injectors, is it easy to replace and what are the costs for an injector? How your recommend new or used?
Thanks again
fxgo
Eswift
ususally it can be done without removing the plenum, but it might be a good idea to take it off and replace all the fuel hoses, as preventative maint.
i would recommend new ones, so there are no worries, although then it is likely that the new one will be fowing differently than the other 5.
you could get a used one, check the ohmage, and then have all of the injectors flow balanced.
or you could just get a used one from ebay and throw it in there.
it just really depends on how far you are willing to look ahead, and if you want to accept the fact that you might have to go in and replace the replacement.
fxgo
I tried getting the Diag codes. The battery was completely dead. I did a load battery tester, it failed. When I use my battery charger, it tells me it is fully charged. I had to replace the battery.
I replaced the battery. The car was hard to start. Once started, the engine ran a little rough. I let the car warm up. The engine light is no longer on, but the power is still weak.
Once it was warmed up, it was easier to start, but it still has no power. I also notice that gasiline/vapors is comming out the muffler system.
Thanks for the help.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Failed injector? There is a post about checking the resistance of the injectors on a J30. But the pintle may have failed on one even if it is still in resistance specifications. If you smell gas under the hood, don't start and check injector O-rings and fuel lines and injector rail for leaks.
fxgo
Thanks again. The weather out side is warm and it is starting without a problem. Do you have any comment on the white smoke out the back. I am very concerned about it.
I hope I didn't blow a head gasket as well. :(
fxgo
Well, I took it to a mechanic. It looks like I might have a blown head gasket. He spoke to the dealer and he told him that he nevers sells head gaskets for these motors.
He will confirm it on Monday. The strange thinig is the car was work fine right up to this point, no overheating or nothing.
Just in case it is the head gasket, would it be better to install a newer used motor or fix the orginal one? Where would you recommend getting a newer used motor?
It is sad, because I have been so religious about my J30 maintence. Things happen.
Thanks.
VimyJ
Never heard of a J blowing a head gasket either. Please keep us posted.
Q451990
I'd take it to the dealer or an experienced 300Z tech. We had a case of a 94 or 95 Q earlier this year that was diagnosed as a bad head gasket. Turned out to be a detonation problem that probably started with non-oem spark plugs. It's worth the extra money to get the diagnosis right!!!
Heath
fxgo
Last Friday, I had a tow truck come to my house and take my J30 to my mechanic.
Before the tow, the tow truck driver asked what was wrong. So, I started the car and I explained my problem. The car started without a problem, but it ran rough. I stopped the car and the tow truck took the car.
When my mechanic tried to start the engine, he couldn't even turn the engine over, hydro-lock. It was like the engine was seized, which could be from water in the cylinders. He removed all the spark plugs and found, yes, there is fluid in two of the cylinders, which is causing the engine not to turnover. The fluid wasn't water, but gas. My head gasket is fine. I had two cylinders filled with gasoline. The Gasoline was causing the hydro-lock.
I will be ordering all six new fuel injectors, two plenum gaskets, new spark plugs (old one had 45,000) and all o-ring injector seals. Since we are removing the plenum, what fuel hose should I replace? Is there a description or would the dealer know what I am talking about.
Believe me compared to a head gasket, I am so happy to be replacing all six injectors, instead of another engine.
I am still a happy J30 owner. This is the first major issue I have had with my J30 and she didn’t leave me stranded either.
Thanks everyone for all your help and good catch on the injectors.
Regards,
Frank
VimyJ
Where are you located? Might give us an idea about the quality of fuel being offered in your area.
fxgo
I live in the New England area. I use only premium gasoline from Mobil, Shell, Amico, and Sunoco. Do you think fuels was a part of it. Unfortunately, there is nothing I could about it.
Regards,
Frank
fxgo
Where I can get infiniti parts from a dealer at a discount?
I purchased the parts from Tom Ryan at Infiniti of Lisle, and he said he didn't do the club discount anymore. He said he would do it one last time for 20% of list.
I need another source for new infiniti parts? Anyone have more sources that give discounts?
Thanks. frank
VimyJ
Click on the add for InfinitiPartsUSA.com
fxgo
I thought they only did speciality parts for Infiniti. I will use them from now on. Thanks..
fxgo
Well, the car is at the menhanic. He replaced all the fuel injectorsTHe two front cyclines (1 & 3) on the passenger is still misfiring and white smoke is comming out the back.
I didn't replaced the power unit. I lasted to shree to be that guy
Please any help. would be greatly appreciated.
Regards,
fgo
fxgo
Any input to the two cyclinders (1 & 3) that are miss firing?
I can use some help. I would appreciate it.
Regards,
fxgo
DAEDALUS
Car: 1990 Infiniti Q45
Did he replace the plugs? Sounds like you had a fuel leak--plug(s) are all fouled up now, and maybe the O2 sensors too. You never stated what the smoke smelled like. Sweet? Rich fuel? Sometimes things get better with some aggressive driving to burn off the carbon. Probably a bad injector seal, but maybe not. I would have the plugs replaced and, at the same time, do a compression check. Number the plugs as they come out and inspect them. Doesn't take long for fuel leaks to start to wear down a cylinder.
fxgo
Thanks for the quick replay. We replaced all the injectors and new seals. We also installed new OEM spark plugs and O2 sensors. The smoke smell is gas. NO Check engine light.
They did a compression test. It's OK. They our testing the signals to the coil pack and injector to see if it is a Power transistor unit.
You can't drive the car down the street.
Thanks again for your input.
DAEDALUS
If you still have white fuel smoke in the exhaust, then my opinion is that you still have a fuel leak. It is easy to pinch a seal. Also, I don't know if you trust your shop, but I have actually had the experience of paying for parts and labor that were never installed. Imagine my surprise when I pulled out spark plugs that should have been replaced, only to find that they still had my initials on them. You have to have the rail pressure checked to see if it is leaking fuel after the car shuts off.
fxgo
At this time, they have given me no reason to mistrust them. The problem isn't fixed and your right I think I have a fuel leak. and or electrical problem with cyclinders 1 & 3. I will call him ask about get the rail pressure test after the car is shut off.
Plus I always ask for my part after the repair. I check my markings too.
Thanks man. I appreciate your help.
Regards,
fxgo
fxgo
The problem turned out to be a connector problem with the Power Transistor unit, which is located at the top rear of the engine. Use Di-Electic Grease on the connectors.
A mod from this site, NISTECH, located the problem and help my mechanic fix the car.
I want to thank everyone for your efforts and especially NISTECH. My mechanic said he was awsome.
Thanks again NISTECH
Regards,
fxgo
tiggermarty
I am having the same sypmtoms that you describe (and they seem to have started occuring around the same time). Do you have any correspondence from the moderator regarding this unit? I will look it up in my manual tonight. Currently the shop mech is telling me I have a bad ECU, but I can pull codes from it no problem - they are Heated O2 Sensor, Injection system, and can't recall 3rd but the codes given were 12, 33, and 51 I believe - will check notes when I get home tonight. I just can't imagine spending the quoted $500 to replace ECU if that is not the problem.
NISTECH
12 is airflow meter which is where he should start his diag. code 51 is injector circuit failure. so you may have some corrosion problems at the injector connector or may even have an open winding in a injector.
DAEDALUS
ECUs almost never fail. Never heard of a bad one on these boards to my recollection.
tiggermarty
The codes I mentioned were correct. But now it seems I'm in a pickle. When I took the car to this mech it was at least driveable. The day after he looked at it I was going to take it somewhere else for a second opinion but it wouldn't go over about 10 mph and only in 1st gear. My suspicions grew but I felt "stuck" there so I told him to go ahead and order the part (you know how some people are just soooo convincing?). So now he has the part shipped in (received it just this morning right when I called to say I wanted to cancel the order - and yes I marked my part so it was a different one). Well from what I've heard here and also from a buddy who works for Lexus the ECU's typically don't just "go bad" and this guy has not *guaranteed* that the replacement will fix the problem so naturally I'm balking at this point. It has been 3 days since I told him to go ahead and order the part - now I'm asking him to ship it back but I'm betting he's going to tell me that I have to pay for the part now that it's in. Do I have any rights in this matter? Help! I feel like I'm being taken to the bank to sign my account over to this guy :P
