Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Oct 16, 2003 5:08 am
Very common [corrosion] and heat damage to rubber boot on connectors. My 300zx techs say as a matter of course they change the injector and KS/coolant temp harness then check every plug in connector in engine bay for corrosion!
The ecu does provide the ground for all injectors [& spark coils]......they get +12 in common from a relay then fused.
Easy with a current probe or an inline 0.1 ohm resistor and cheapo oscilloscope] [substituted for the fuse] to look at injector waveforms [or spark coil waveforms].
I get very upset when people use mechanics as very few life threatening things are mechanical......bolts may shear and bridges collapse. Chain guides, vibrations, etc.
Unless the engine has been oil abused [or is just worn out] 95% of problems will be electrical in nature prior to 250,000 miles.
When they say they don't have or need a Consult and lots of other expensive diagnosis equipment ------------run away fast!
