haltech ecu..
zero_gripS13
Car: soon to be 95 s14 hopefully
where do u guys buy these at.. i found a few sites but they dont look trust worthy...
thanks
CA19DET
try TopEnd Performanceemail Steve, i have gotten allot fo my stuff from them.. they also have sensors and flying lead harness' etc, they are a authorised HALTECH distributor as well..
http://www.racetep.com/haltech.html
Morph
Car: 91 Sr Powered Coupe
Very good company im getting the e6x in a week or so.
zero_gripS13
is the haltrech plug and play or do u got to wire everything up?
id probably have a shop install it but was just wondering
CA19DET
NO its not plug and play
there is a plug and play Haltech Unit but not for our application yet -
you "can" use your existing harness, cutting off the ECU plug, and wiring/pinning it up to the haltech ECU plug.. but you have to use the needed haltech sensors like Air Temp and Water Temp..
BUT
it is a better idea to get a flying lead harness, lay it out in your engine bay and make it up there, it will be allot neater and easier to trace faulty wiring, bad grounds and miss behaving sensors...
good luck
Morph
Pretty sure that the PigTails should be out by then end of the month or so but not sure what applications its going to be best sutied for.
