gauge Faces
damnthecops
Car: 1989 Nissan 240sx Coupe
i just got new gauge faces off e bay and i pretty much knwo how to put them on except there is 2 wires(red,Black) that they say i have to attach to the light control.... does n e body know where i connect these or any easier way to run it so when i turn on my lights the guages turn on.. thanksomar:ylsuper
kansas240
Car: '00 Nissan Xterra 3.3
The new gauge faces being white replacements for the black stock ones? if they have auxilliary wires that need to be powered when the lights come on, use the black wire from the white plug that is about 12 inches from where the gauges plug in (it is a 18 gauge while others are 20/22), solder in a new ground jump wire. then locate the blue wire from the same plug. that one should be hot only when you turn your headlight on. again, solder in a jump wire.
Genetic_Drifter
Car: Drifting with my car and mind!!!
Hi,i just recently got face gauges off ebay also...but i don't know how to install them any ideas on how to install them???
damnthecops
i figured out how to put mnine on.. after installing them its all a matter of wiring them... after u put them onto ur gauge cluster go to ur headlight switche... connect the positive wire( i think red) to the green wire(this is if u have a s13) otherwise u have to slice the plastic open and try every wire...BUT DONT CUT THW WIRE!!then once u find the one that works wiht ur lights thats the one... and u connect the black one to anything metal where it wont fall off i put mine on my steering wheel column.....always have the black one connect to something grounded so when u find the right wire ur guages light up its not too hard
Bussman240sx
Car: Nissan cars, and women
GENETIC_DRIFTER
this is a site that will give you a step by step on how to remove your gauge cluster and it includes pictures as well
http://sr20.hybrids.jp/installations/in ... index.html
