Modified by JDMSIL80 at 12:18 PM 8/4/2005r34 gtr wrote:ok, youll need to remove the heat shields from the manifold to get the compressor to clear. youll also have to use two manifold --> turbo gaskets. youll have to bend the oil lines or get some braided ones. the ssautocrap o2 housing wont even begin to clear so youll have to use the CA one.
its a big difference, i wouldnt want to run it without upgrading the fuel system or MAF. i maxed out my maf in a real hurry on 7psi. damn thing would only get me to about 5k in the higher gears.
- tim
I had none of these problems tim speaks of here. No heat shield removal, or double turbo gaskets. Barely fits, but fits for me... only thing needed was a new oil drain flange for a GT series turbo.r34 gtr wrote:ok, youll need to remove the heat shields from the manifold to get the compressor to clear. youll also have to use two manifold --> turbo gaskets. youll have to bend the oil lines or get some braided ones. the ssautocrap o2 housing wont even begin to clear so youll have to use the CA one.
- tim
I have a like brand new GT28R for sale cheap, email me at [email protected]JDMSIL80 wrote:Due to financial difficulty, I'm trying to get a turbo upgrade that requires the least parts to add-on just to get it going.
Would GT28R work well with stock components for the time being? Or do I still need to upgrade injectors, MAF, fuel controller all at the same time at least??
If the costs is too much, I may just end up re-building my stock T25 to get it running. Help me out guys~
You can buy the same/similar turbo from HKS, Garrett, and Precision. Anything else will not be a real GT turbo and likely will be totally different. Garrett makes these turbos and they are re-branded as HKS or Precision etc. Precision also casts their own housings to reduce the cost some. The HKS ones have extremely high mark-up in price on them. I would go with a Garrett version.slownslurious wrote:am I wrong, or isn't it true that there are different brands of a "GT25" turbo. I mean you could buy a garrett one, an HKS one, ss autochrome one, turbonetics one, etc... my guess is that they are probably slightly different externally while having identical specs...its a guess though. I do that a lot.
CHRA's are the same. HKS puts on some super duper special compressor wheel and housing though. As if Garrett doesn't know how to make a turbo.slownslurious wrote:well, any turbo with the same specs would still probably sell as a GT25.also the HKS units have different wheels and center sections, I believe. If precision casts their own housings then they are probably different... even a small difference would explain why some people have "just barely" put it on and others have "just barely" not.
- tim
float_6969 wrote:It sounds like it is. If the only thing you did was what you stated, you could be maxing out the MAFS. Do you have any leaks in the intercooler piping. Are you sure you're only boosting 7psi? What is it doing in the upper gears? (3r,4th, 5th) If you've got a friend with a SAFC and a larger MAFS, you might try swapping them in temporarily and see if that fixes your problem.
