You would need the .64. The .63 is only for a T3 housing. The .86 would be too big. I don't know about clearance. I bought a tubular manifold just to avoid it in case it was a problem.JDMSIL80 wrote:^The GT2871R has four housing A/R size of .63 / .64 / .82 / .86
Which size is would be the choice on CA motor with least low end lag?Also, would the stock manifold clear this turbine housing w/o problem?
Modified by JDMSIL80 at 8:53 PM 7/26/2005
Turbine... compressor is just a standard T04B housing with a .60 A/Rfloat_6969 wrote:are those for the compressor side, or for the turbine side?
clearance will also be an issue with the motor mount. On the s14 SR turbo (gt28r) you ALMOST hit the motor mount (1/8 inch or less). Anything bigger and you will have to make something custom.c-rad wrote:I don't know about clearance. I bought a tubular manifold just to avoid it in case it was a problem.
ssautochrome is the only one who makes an easily available mass produced bottom mount t2 flanged manifold. you could have someone make it for you, but for $165 for the manifold and dump pipe why would you?JDMSIL80 wrote:Which tubular manifold do you recommend for my setup? Thanks for your help!
Sean
no, they are the same size physicallyJDMSIL80 wrote:Thanks for pointing this out.
Is the GT2871R bigger than GT28R and may not clear the motor mount?
