PapaSmurf2k3 wrote: ↑Sun Mar 29, 2020 11:09 pm
Sounds like a bunch of problems that have gone uncorrected, and not necessarily related...
High idle could be a vacuum leak.
Bingo. High idle could also be tps or timing. Fortunately most of this you can check or adjust with a multimeter and timing light for free.
As for the battery, you can have that and the alternator checked for free at most autoparts stores.
As for the radio, that sounds like a bad connection or bad ground. Did you install an aftermarket radio or buy the car with one installed? I'd be willing to bet if its aftermarket its a grounding issue. Pull it out and inspect the harness. If the ground isnt hardwired to chassis itll attempt to ground through the DIN frame. Make sure all 4 screws are installed securely that anchor the radio to the dash. Check the ground wire and make sure it's got a good connection to ground.
What do you mean by, "it leaks a lot"? Like coolant, oil..? Where from?
What voltage is your battery currently at? How old is the battery? What condition are the terminals in?
And 1800 rpm idle isn't 'fine'
Once you get your battery and starter issue resolved:
https://www.nicoclub.com/archives/ka24d ... -idle.html
https://www.nicoclub.com/archives/240sx ... iming.html
Listing of articles:
https://240sxtech.com/
