bruinbear714 »
https://forums.nicoclub.com/bruinbear714-u1106.html
Tue Oct 28, 2003 8:44 am
Most likely the afc has a lookup table, with one axis being rpm, the other being throttle position. In each entry in the table there will be a modifier number, which adds/subtracts the incoming MAF voltage and spits out the modified voltage to the ECU.
So your area of interests would be the entries in the tables where throttle position is at its lowest (I believe 0.5V is when throttle plate is closed), and where rpm is lowest
I am not 100% sure of this, but if you send me a screenshot of the software with the table entries I'll be able to tell you more.
