DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu May 01, 2003 5:27 pm
I've always removed the tube. It might actually be loose enough to remove with your hand, though you'll want to tighten it with a wrench if possible. Also feel in the exhaust port with your finger if you take the tube off to make sure it's not clogged just past the tube. If you decide not to remove the tube, a flexible bore brush or burrette brush would probably work well. Hobby shops sell long flexible plastic and metal rods for RC airplane control, too, but without any brushes. Maybe $1-2. Ideally, you could find a threaded bore brush head that was the same thread as the threaded pushrods. Whatever you use, make certain it won't come off the rod, or you'll likely have to remove the tube to get it out.
