biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Wed Sep 14, 2005 10:07 pm
with some help from a friend (most notable he provided the drill), got me e-fans mounted. there's a problem with the SMIC piping now not fitting but that should be corrected tomarrow (today) .. I can only close the hood because I force it to close ATM.. the piping wants to go through the top driver's side of the fan shroud.
the fans are brute force, dual 11" SPAL fans, moving a rated 2780 CFM of air.however they're not very loud. there's a distinct but faint "whrrrr" sound and the sound of moving air, thats it. There's are better than most OEM fans.. tho they're listed in the "OEM" rather than "Aftermarket" section of SPAL's website
the mounts, and fans and shroud themselvse, are strong enough I can shake the car by grabbing onto the motor baskets and shaking it.
the mounting is pretty simple.. a peice of 1/8" x 1 1/2" x ~24" flat aluminum and another same dimensions more or less, but L shaped.
flat on top, L on the bottom.
on the top drilled holes to mount to the efans, and to the radiator, same on the bottom, although while the radiator has tapped M6x1.0 holes to bolt to at top at the bottom it has a pair of horizontal bracket things that have a ~1/2" hole in them.
I spent under $30 for all the parts to do the actual mounting and have tons of alum left over (since they were in 6ft lengths)
this almost didn't fit.. so you'll notice in the pics that its tilted slightly.. at the passenger side, avoiding the rad hoses, and at the driver's side, avoiding the frame rail.. it is slammed right up against the frame rail there, and just barely is high enough on the passenger side to clear the rad hose there.. and the tilt induced by the frame rail allows it to clear the top rad hose.
on the bottom to fit those rather large mounting holes I found at a hardware store (Elliot's, they got tons of stuff! only local in Dallas area tho, not a large chain) some rubber thingies with threads in them, the sort that when tightened cause the rubber to expand and lock in place; don't care about the locking but they're the right size to make dual function standoffs (as they have a lip) and vibration insulators. so put a bolt down from the L bracket to those, with a spacer made from spare front a STB nut, and that takes care of the bottom mounting. also the lack of space necessitated cutting out notches in the efans shroud to allow the bolt to fit since the head would otherwise run into the shroud.
at the top, we had to put the whole thing in when the rest of it was done and mark where the top bracket we were fabbing up met up with the radiator's mounting locations.. then take it back out and apart so we could drill them.
we still haven't blocked off the driver's side where the shroud sticks out past the radiator but it scarcely matters right now, I'll take care of that when I have to take it all off again to replace the AC condenser. we blocked along the top and bottom edges w/ foam (also, as with the rest of the nuts, bolts, alum, etc, from Elliot's), some sort of self adhesing stuff for marine/automotive use (or so the packaging said). the passenger side the radiator sticks out further than the shroud anyways so nothing to block (it should be noted that the shroud vertically has sides but along the top and bottom its cut away, presumably so you can use that space to mount w/ brackets or such)
right now I've sort of hack wired them up via the stock water temp switch in the lower rad hose and the existing relays I had setup the AC condenser fan to operate before it died, but later I'll rewire them properly; I'm going to have one fan operate with a lower temperature thermoswitch (probably from a FWD CA, which activates at 180-something or such vs 198F), the other side via a pressure switch on the AC system (replacing the stock cutoff switch with a cutoff/fan activation switch so that instead of trying to guess when the condenser needs help from the increased water temp, it'll base it off the actual pressure inside the system), and then have them both kick on when the normal 198F thermoswitch activates and/or I manually toggle a switch (might never get around to the switch)
the fan control will be simple using merely 4 rectifying diodes oriented such that a ground at either side only activates that side but one in the middle will activate both relays simultaneously
anyhow, the pics:
top mounting bracket, driver's side:
same, passenger's side:
bottom mounting bracket:
again, but closeup of one side where we had to cut it out a bit to fit around the lower radiator hose:
and installed:
Modified by biosehnsucht at 2:30 AM 3/21/2009
