RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Mon Mar 01, 2010 11:12 pm
The b15 transmission or the p11(2001-2002 g20t) transmissions are the best setup as being the strongest. The b15 transmission has to be from a Performance Package/SE model which is limited slip differential. Very limited made for 2000-2001. The g20 transmission must be from a touring edition 2000-2002 to be limited slip differential. Now don't be confused, any SR20 equipped car's transmission will work, but those are the strongest. You can obviously used the b14 200sx se-r transmission, 91-96 g20 transmissions, 91-93 nx2000 and the 91-94 se-r, which you don't want because they are prone to 5th gear pop out.
Any g20 transmission must be a touring to get limited slip. With the earlier g20 transmission, the gearing was taller and beneficial to turbo setups. If you find a non touring g20, you can still use the transmission, but you will have to switch out the gears from the non limited slip transmission and install them along with the limited slip differential and use the outer case from the limited slip car.
If you end up with the b15 transmission or later model g20t transmission, you must convert the hydraulic setup to accommodate you cable setup, takes about 30 minutes to do.
