Start with low boost settings (sub 15psi) and start by using your trim knob in areas that shows either rich or lean. If you are lean from (example) 4000rpm-6000rpm with an A/F ratio of 14:1-15:1, you'll start adding 2-3% fuel at or around 3800rpm until your a/f ratios get to the desired ratio you want (preferably 12:1). Timing in your case is somewhat tricky, but I recommend your max timing at say 23 from about 2000rpm onward. Keep in mind you have to be listening for detonation. Since your compression is a bit higher, it would behove you to put an octane booster in your fuel. Any more Qs, you know how to find me.............Good luck!float_6969 wrote:Well I'm gonna get this thing fine tuned. I know my timing isn't right and I'm sick of it. Plus it's too rich and turning my bumper black.
I've done LOTS of research and I feel like I'm very well educated about the in's and out's of tuning, but as always, experience is the best teacher. As I've never been to a dyno before, I don't know what to expect, or what to plan for. I feel very comfortable with the SDS now, and it's tuned well enough to drive it daily, but I can feel that it's got a "dead" spot in the powerband down low and it tuned quite rich still (12:1 or richer).
So my question is, to all of you who've got experience, what do I need to take, what should I expect, ect.
Also, I'm borrowing my Dad's digicam, so I should have lots of video and pictures. I'm hoping that I can also get copies of the dyno sheets somehow. (Do they give you a disk, or do I have to have printed copies scanned?)
Any suggestions would be greatly appreciated.
Thanks,Ryan
I'll be starting at the stock wastegate setting for an SR T25, which is right at about .5 Bar via my Autometer boost gague.boost_boy wrote:Start with low boost settings (sub 15psi) and start by using your trim knob in areas that shows either rich or lean. If you are lean from (example) 4000rpm-6000rpm with an A/F ratio of 14:1-15:1, you'll start adding 2-3% fuel at or around 3800rpm until your a/f ratios get to the desired ratio you want (preferably 12:1). Timing in your case is somewhat tricky, but I recommend your max timing at say 23 from about 2000rpm onward. Keep in mind you have to be listening for detonation. Since your compression is a bit higher, it would behove you to put an octane booster in your fuel. Any more Qs, you know how to find me.............Good luck!
Dee
I've snooped around that site some. I probabally need to hang out there a little more regularly. I'm not registered.fanta wrote:http://www.efi101.com/forum/Great forum- knowledgable people, everything from seasoned builders and tuners to dyno operators and distributors.
What dyno will you be using?
Well do something man. I MISS YOU!! Ok, not really. I just miss making fun of you.r34 gtr wrote:ive got a tip for ya, TEAR SOME A$S!!
oh, and last time i went they emailed me the charts from my different runs. i dont doubt they will put them on a cd for you. now if only i could stop being lazy and go to the dyno as well....
- tim
p.s. - sorry i havnt been on in a while but my laptop died and i havnt had time to get a new one (or money for that matter)
I don't know to be honest. I used to hang with the guy, but I definatly wouldn't have called him a 'tuner' by any means. I mean him no offense, but it's more of a rice shop. Mostly wheels and body kits. He does do motor swaps though, but I don't know how much standalone tuning he's done.Not_a_sr wrote:is the dyno operator knowledgeable in tuning? dont be afraid to ask advice/help.. most dyno people will go out of their ways to help you out.
Plugs are brand new, but I'll bring another set.cortinka wrote:make sure your spark plugs are already gapped and in real good condition..take some spares just to be surecheck hoses and clampstake some mechanix gloves ..just in case you have to check around the engine after a couple of runs...coz it will be hot...be knowledgable about its conditon and mods... so you can inform the operator of the information he needs to know
just make sure that the car is ready to run..no delays cozdyno time is all $$$
Unfortunatly, I've already got the 99 octane in the tank, so it's too late for that. If I have a problem with the pump fuel knocking (I'm only running 7psi on pump fuel, anything higher and I'll use race fuel), I'll pull some timing out of it.CA19DET wrote:i wouldnt tune with the race fuel, make sure you do all your tuning on the gas you will be running everyday, then if you can make a special maps for the 98.. save your original maps to a diskette too incase you ever make a mistake or something.. and back up your tunned maps before playing with the high octane maps..
i would also walk with a cooler with soem dry ice and a bottle sprayer/mister for the intercooler,its really hard to get teh same results on teh street cause of heat soak.. spryaing the intercooler and rad occaasionally helps..
Damn (off topic) 6000 posts! What a frickin' whore.......float_6969 wrote:Unfortunatly, I've already got the 99 octane in the tank, so it's too late for that. If I have a problem with the pump fuel knocking (I'm only running 7psi on pump fuel, anything higher and I'll use race fuel), I'll pull some timing out of it.
I'm also using SDS, so I can't save my maps to a disk or anything. I'll just record everything down when I get done at the dyno, and then if I change it, I can revert it back when I go to higher octane. One of the few drawbacks to SDS I guess.
I had planned on taking a sprayer for the radiator and intercooler. I don't know what kind of setup this place has and what kind of air flow we're going to be working with.
