Davezilla »
https://forums.nicoclub.com/davezilla-u195464.html
Sun Dec 25, 2011 1:02 pm
I know this is an old post, but there are 2 things out there that grease just can't stand up to...
1. WD 40 .... use for small areas along with plastic bristle brushes and rags to break down the grease and use a little more for final cleaning, the part will look like new when done.
2. Automatic transmission fluid ... Grease just cannot stand up to this stuff. Works best if you can remove the part and let it soak, if you don't have time for a good soak you can put about a gallon or so into a "wash tub" where you can use the ATF as your cleaning agent. You can use brushes, rags, etc for scrubbing if needed. Once parts are free of grease, final clean with your fav dish soap.
If the parts are still on the vehicle and you don't intend to remove them for cleaning you can always use rags soaked in either the wd40 or the atf which can be laid on the parts or tied to the parts. scrape or brush off as much caked on grease as possible first if you can to further reduce cleaning and soak times.
another thing Wd 40 works great for is to remove old decal and tape residues, just spray on, wait a few minutes and wipe off... repeat as necessary, letting it soak longer makes it work better too.
