Post by dasoupdude » https://forums.nicoclub.com/dasoupdude-u92506.html Sun Sep 21, 2008 3:15 pm
Post by yelohandL » https://forums.nicoclub.com/yelohandl-u105740.html Tue Sep 23, 2008 5:48 pm
wow i read in a megazine stock 08 Z on a dyno and it pushed around 235hp and 201 ft torque at the wheels. it was on "modified" megazine.why are the numbers so low? kind of disappointing.xjmxstac wrote:
First off, the de engine on 2003-2005 non rev-up pushes 287hp @ 6300rpm (crank) and 276lb/ft @4800 rpm (crank). That translates to 249 hp @ 6300 rpm (wheel) and 240 lb-ft @ 4800 rpm (wheel). Second, the weight of of all z's vary by trim/year, which has, by the way, nothing to do with the car's whp. Now for the hr's: they put out about 306hp @6800 rpm (crank) and 268lb/ft torque @ 4800rpm. Take 13.2% out of that (because both versions of the z has virtually the same gearbox, driveshaft, and differential) and you get your wheel horsepower. Welcome to NICO noob!
Return to “350z / 370z Discussion”
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
