hiimjered »
https://forums.nicoclub.com/hiimjered-u98712.html
Thu Jul 03, 2008 5:19 pm
Someone who knows more, please correct me if I'm wrong, but:
Short answer: yes the amount of fuel injected can vary depending on work being done.
Long answer:The amount of fuel the injectors release is based on a combination of information coming from the MAF sensor and the upstream O2 sensor. Basically the amount of fuel injected is dependant on the amount of oxygen entering the cylinder.
So fuel usage should be consistent for a given amount of throttle. When you open up the throttle, more air is released into the engine, sending a little more into each cylinder. The injectors pump fuel to match the added oxygen and a little more power is produced, spinning the engine a little harder and producing more power. If the amount of resistance increases equally, the RPMs will remain the same, but the fuel usage will rise.
Still that increase is unlikely to be nearly as significant as the increase in usage as RPMs increase. The amount of fuel used at a given RPM speed is unlikely to vary more than 25% while the amount of fuel used when spinning at 3k instead of 2k is naturally a 50% increase.
RPMs should be a really good gauge of fuel usage (although if you are really curious, you could get a scanguage 2 but overall, the harder you press the throttle the more fuel you use.
Once again, I'm not an engineer, so I could be a little off.
