Gear Oil
cmartyn
Car: 2021 Nissan Rogue SV AWD
So, I was looking at the old manual and under capacities and lubricants we have a suggestion for rear dif and transfer case lubricants which are different. Full Synthetic up front, Dino Oil in back? Seems weird most.people seem to just buy Mobil 1 or Kirkland depending on their persuasion. I've never seen anyone use two different oils. They are both close to the same price.
Differential
Genuine NISSAN HYPOID FLUID·S1 GL-5 75W-80 or equivalent
999MP DF300P
Transfer fluid
Genuine NISSAN Differential Oil Hypoid Super-S GL-5 synthetic 75W-90 or equivalent.
999MP DF700P
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I assume you mean tran-sfer and not tran-smission. If you don't put in a hyphen, the editor here turns tran-anything into transmission.
GL5 oils get almost all of their pressure strength from additives, and in my experience it doesn't make a whole lot of difference whether the base oil is refined or synthetic. Maybe in a race car, that's different. In this case, the real difference is the viscosity index. The tran-sfer cases take a tiny amount of oil, 5/8 pint, and maybe that explains the higher vis. BTW, the diff couplers on gen3's also have their own oil, basically fancy LSD oil. The spec is for Nissan LSC Coupling Transmission Fluid 12-301 or equivalent.
cmartyn
Thanks, Yes, I meant "tran-s-fer" case. I couldnt find any sort of maintenance schedule for changing the coupling oil. Only to inspect it every year or 12,000 miles. Not even sure how to change it lol.
Ok, well, I can't justify spending 60.00 a quart on Nissan fluid. My dealer here has to order it. Everybody seems to like the Motul brand over at Bob's the oil guy.
VStar650CL
Technical Expert
Yep, I agree the Nissan fluids are very overpriced. I've been b!tc#ing about NS2/NS3 that way for years. There's no harm in using Mobil or any other good GL5 in the diff and tran-sfer. I don't know if you'll find any equivalent for the coupler fluid, I couldn't find anything last time I looked. FYI, it takes 1-1/4 pints and there's a fill/level plug on it similar to the diff. I definitely recommend checking it once in awhile, since the coupler is basically the weakest link in the whole rear drive. There's no drain plug, so when you want to change it, I recommend using a sucker. If you remove the reservoir plate then the coupler needs to be bled and you need a Consult for that. Doing a partial spill-and-fill with a sucker like doing a CVT spill (replace whatever you take out) is a better idea. Make sure you shake the bottle of coupler fluid before use -- just like some electronic LSD oils, it has metallic elements which can settle out in storage.
V6er
Car: 2014 Nissan Rogue T32 SL
2023 Nissan Rogue T33 SL
Only thing I wonder - is that 3rd gen awd engagement unit really nissan or haldex?
VStar650CL
Technical Expert
I'm sure it isn't Nissan. Hitachi makes a lot of the diffs, I'd say they're a good bet for the couplers too.
V6er
hmm... hitachi... will check what I can find :D
cmartyn
Well.. I decided to do a 75w90 up front and a 75w85 in back. I got my wrenches and pumps.. does anyone know the part number for the alluminum sealing / gasket washers? Just a quick look.. they look to be M14 bolts but these washers are super thick. It's a 21 Rogue and none of the part sites list them.. only earlier ones. I saw some black anodized ones for the GTR.. fancy pants. 20 bucks lol.
V6er
cmartyn wrote:
Fri Mar 28, 2025 7:28 am
did you look at parts catalog, did you go to dealership parts department?
cmartyn
I looked at the parts catalog. It doesn't even show them. Well, I couldnt see them. They dont even show the drain plugs. I didn't go to the parts counter yet. That's my last resort as it's a 30 mile round trip.
V6er
cmartyn wrote:
Fri Mar 28, 2025 7:59 am
All those washers sometimes are hard to find, but they are there. Later today I can look what I have gathered - I think I got all the partnumbers.
cmartyn
That would be great. I mean, the drain plugs and washers for the trans and engine pan are easy to find.just can't find these.
The online parts sites seem incomplete. A lot of them have the transaxle link pointing to the interior console so if you need a sealing washer, your out of luck but could we interest you in a new arm rest?
V6er
treat it with grain of salt - I am not sure how far did I get with fact checking (I remember going to dealership to check part numbers, but I am not sure - is this list BEFORE or AFTER that visit :D and now looking at parts.nissanusa.com catalogs - looks like they have "cleaned out" a lot of information.
anyway
11026-1CA0A - this seems to be transfer drain and fill plug gasket. used to be less than 4usd. I think these were aluminium.
11026-4N200 - this seems to be rear diff drain and fill plug gasket. these also might be aluminium.
11026-JA00A - cvt drain plug washer
31397-X230A - cvt oil pan gasket
cmartyn
Thanks, Those part numbers are the common ones for the Rogue. One of them looks to have a thinner shoulder, probably for under the flange cap screws and the other one is wider probably for the regular cap screw. Whatever. if they don't fit.Ill just reuse the old ones like everybody else. I'm sure they will fit. I will.take some.pics.
V6er
take pics and measure ;) good luck!
cmartyn
Thanks. I managed to find a more complete parts manual by searching lookup codes and Nissan Rogue eventually landing on a bunch of Spanish parts books. They confirm what you said as far as washers go. I got the drain and fill plug numbers too. This is for 2021 SV AWD..
TRANSFER CASE
11026-1CA0A WASHER (2)
32103-MA00B Drain / Fill PLUG (2) No Magnets
Rear DIFF
11026-4N200 WASHER (2)
32103-4N20C PLUG Drain Plug with magnet
32103-4N21D Fill PLUG
cmartyn
Well, the difference is the thickness of the washers. The diff washers (4N200) are 1.5mm thick and the 1CA0A for the front are 2.0mm thick. Remains to be seen what exactly comes off the car. They are both just 24×18mm aluminum sealing washers.
cmartyn
Well, we get around to everything eventually. And, big SURPRISE!!! They moved the drain and fill.plugs to the passenger side of the diff. Threw me for a loop. Anyhow, the 1.5mm washers are indeed used on both the drain and fill plugs. My 2021 is a Japan built.with 8500 miles on it. Built 4 years ago so I'm 2 years overdue by the book but the fluid looks pristine and there was very little build up on the drain plug magnet.
cmartyn
Just to close this out, did the transfer case today. Observations, the washers are for sure thicker on the transfer case than the differential.
The fill.plug on the transfer case has a 14mm hex head and not the 10mm allen key.
Nissan rerouted the exhaust so the whole thing is much easier than it used to be. If you insist on tightening the fill plug to the correct torque you will need a 3/8 digital torque wrench and a low profile socket. There was no room for my craftsman and I used a long extension to come at it from behind the wheel. I dont have a part number for that 14mm bolt and the Nissan parts catalog doesn't show it.
Boulder.rogue
@VStar650CL
@everyone
I need help please as I want to do drain and fill my transfer case on my Nissan rogue 2021 but could not see any info where is the fill plug.
I have attached a photo and marked the plugs.
Do I get it right?
Please help.
Thank you
VStar650CL
Technical Expert
The blue one is the check/fill plug. The red ones are both drains but you only use the one facing downward.
Boulder.rogue
VStar650CL wrote:
Sun Oct 26, 2025 7:21 pm
Thank you sir. We are lucky (diy'er) to have you on this forum.
VStar650CL
Technical Expert
:dblthumb:
V6er
Boulder.rogue wrote:
Tue Oct 28, 2025 8:59 am
absolutely!
italian926
Car: 2021 Nissan Rogue Platinum 2.5
man oh man, I have a 21 Rogue AWD 2.5 and I THOUGHT I was all set with just doing my transfer case and rear diff, until I came across this post. Thank you VStar650CL for mentioning the coupler fluid, I had no idea. Not a single youtube video on this fluid type change Wow. I did find a video on an actual replacement of the whole coupling for a 2023, and it skips over the fluid refill process. I found a TSB involving the coupler, here is a screenshot of the refill section. So my question is, do we drain and then fill to point of overflow? You mentioned replacing what you take out, and that is confusing me . Link to whole tsb https://www.tsbsearch.com/Nissan/NTB20- ... e_vignette (page 40)
Was there no "coupler" previous to 2021 Rogues ?
VStar650CL
Technical Expert
There was a coupler on the gen1/2's but it was a sealed unit. You can only check/change it on gen3's.
Fill to the check plug, but you might want to compare what went in with what came out to make sure it's right. If not, recheck it after driving a bit. Trapped air can be an invisible bitc#.
italian926
Thanks again, I have a stupid question. The TSB above mentions not using a fluid pump that hasnt been used on other fluids. Is that overkill? If its important, how do we clean out these tubes from previous oil ? should we have like dedicated pumps for various viscosities ?
VStar650CL
Technical Expert
For extraction you can just use a clean pump, but to refill I'd use a dedicated setup. They tell me the coupler fluid is a little like CVT fluid in one way, even a few drops of pollution with the wrong chemicals can ruin it. Don't take chances, those couplers a very expensive.
italian926
Hi there, Im doing my fluids today, just wanted to share that I found fluid for the coupler , and has got that 12-301 stamped on it , whatever that means. https://www.fcpeuro.com/products/audi-h ... -g060175a2 Bought all my fluids from one place and just added it for simplicity even though the price was comparable to OEM . It is THE only fluid I could find with that specification, so maybe this company produces the OEM fluid.
I also ordered 75W-90 Royal Purple MaxGear synthetic for the transfer case rated Gl-4 or GL-5 , and 75W-80 (GL-5) Febi Bilstein for the rear.
SMMac
Car: 2021 Nissan Rogue SL AWD
So, after trying to delineate from the posts of some very knowledgeable folks in this thread, am I safe to conclude that Mobil 1 full synthetic 75w-90 GL-5 gear oil is safe to use in the front and rear differential as well as the transfer case of my 2021 Rogue SL AWD?
Return to “Rogue Forum”
