Gauge cluster
Big Rich
Car: 1993 240sx fastback
I have a issue with my cluster. the speedo works but the rpm gauge does not. Can anyone tell what could be the cause or at least put me in the right direction?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Check out the service manual: http://www.nicoclub.com/FSM/
I would say check each speed sensor and the power going to the Tachometer.
Big Rich
i did the sr swap and now the tach works and the speedo is shot lol.
sabretooth91
Car: 1989 240SX coupe
Infinitiguy19 wrote:Check out the service manual: http://www.nicoclub.com/FSM/
That link is priceless!
NicUzumaki
Car: 240sx-dohc swap
82dodge Rampage[RIP]
when the engine swaps are done sometimes when u have a coil pack pre opp but a dizzy/coil post op u have to butcher your wires, by taking a three pin and a four pin, and make six pin out of those, well your left with one extra that wire is the tach signal
at least thats what was up when i did my ka24de swap
good luck
sabretooth91
Thanks. Yeah, the guy I bought it from did an engine swap. Needless to say..... not pretty.
NicUzumaki
ya so look around your dizzy for a green wire with a black stripe,
if you have that wire run into down into your passenger area and patch it into a yellow wire with a red stripe
and that should make your tach work
