djtorello »
https://forums.nicoclub.com/djtorello-u90321.html
Mon Jan 18, 2010 7:00 am
Ok, well even though they make whiteface gauges or any other color you could want for the B16's already, im looking into something a bit more unique, stateside.
The Renault Megane III is the Nissan Sentra's Sister car. Does not have the 2.5L option. However the MR20DE is the same engine found in the Renaults, Technicely its their engine anway. They have 2 diesel options, a N/A option and a Gas turbo option as well. So what does this have to do with a gauge cluster???
Well some research has revealed that the BCM and ECU are the same, just Different tunes for the ECU. It seems the Renault gauge cluster is a Plug and Play. I can deal with reading everything in metric.
so here is a pic of the cluster from the diesel. Ive found part numbers for the Gas Turbo, but no pics, where as the Gas turbo redlines at 7k rpm, not 5k rpm like the pic below....
What do you guys think? BTW, there are plenty of forums for our sister car, but usually in French or German language. Though i can speak both languages a little bit, i cant read them, so help is needed.
