Gasoline & Oil Mixture
jsando2
Car: 1993 Nissan 240SX Hatchback
2009 Nissan Murano SL
Update: I ordered the right spacers for FI's fuel rail, I will receive them next week (Wed). Once I put the rail back in properly I will test them but first I have to fix my EGR Tube since I ordered one as well, I just had the original EGR Tube cut and will use the Connector of the new one by cutting it as well and then weld both lines. After that I will do a compression test and check the numbers.
Well wish me luck i hope I didnt messed up this engine after all it has been fun! If so well then next is going turbo (SR20 DET)
jsando2
jsando2
jsando2
Update: Im still waiting for my EGR Tube so I can get the car running. I got my fuel injector leak but still I'm afraid that the engine had suffer too much! Well I will check cylinders pressure after installing everything. Wish me luck!
