For all you gas tank leak guys... old motorcycle tanks were soldered from two halves to make a tank..now you don't use a torch.. you use a heated solder iron and flux and solder. I just completed a 1929 101 indian... it is a soldered tank...as for a car tank..I just finished a conversion of a 92 240SX engine swap with a 2008 350Z motor. I also swapped the entire body harness and kept all emissions. The 350Z used two fuel sensor pickups... I simply fabricated an additional "tower" to house one more sending unit, located it in the spare tire area, transfered the location to the tank and soldered it on with an iron.
It soldered just about as easy as soldering copper pipe. I pressure ckd it with air and water... no leaks, but to be sure I sealed it with tank sealer form eastwood, it's been in over
a year now
make sure to wash tank out first,use warm water, and DON'T USE A Torch
the silver in this pix is sealer I applied to the outside as well...patches could be soldered on the same way
