G50 fuel pump vs Z32 fuel pump
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
I’m going to buy another fuel pump and have read in the past that the 90-96 G50 uses the same fuel pump as the 300ZX twin turbo of the same years. If that is true then I would need to get the DW300 fuel pump from Deatschwerks rather than the DW200 that the catalog says the Q45 uses correct?
According to their catalog, the 300ZX na uses the DW200 and the TT uses the DW300.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
PUMP-INF#17042-60U00
that is the nissan part number for the G50. Can't help you with the DW equivalent.
mattd1979
Do you remember reading in the past that the G50 fuel pump was the same as the Z32 twin turbo? The non turbo version of the Z32 flowed less fuel than the turbo version. I’m trying to avoid buying a pump that is underrated for the G50 if I can help it. I just wanted confirmation first. The people that would know for sure don’t seem to be on here any more. Q45tech talked about it but using the search function to locate his posts leaves a lot to be desired.
