pbedrosi »
https://forums.nicoclub.com/pbedrosi-u41754.html
Thu Nov 30, 2006 6:38 pm
My car has been vibrating since day one, but it had been parked for a while so I thought the cheap Dunlops had flat spots. Well, between storage and shipping the car, to a recent time spent having the trans replaced my car had been sitting for about a year total.
When I got the car back after the 94 trans installation the car vibrated like crazy, almost as if all the wheel weights fell off. I'm freaking now thinking its the trans swap, but I remind myself how long the car has been sitting.
Next day I install 16" tires and wheels from our Quest van (new) to rule out the trans. Well I got rid of 75% of the vibration, but the remainder is bugging me.
During startup the car shudders a bit then smooths out between 10-30pmh, but when I reach 35-40mph the car really sharts to vibrate. I think my actual speeds are higher considering 16" wheels and 65 series tires. First gear starts are a bit better but not by much.
As I speed up the frequency increases and vibration starts to disappear around 80-85 mph. I can still feel the vibration in the center console and the seat, but not as bad as at 40mph. While decelerating the car still vibrates, regardless if I'm in gear or in Neutral. Again, when the car slows to about 50 the vibration starts to get bad, peaks at 40 and smooths out below 30.
When I had my oil changed at the local infiniti dealer the tech could only find bad rear shocks and busted engine fan (clutch I think, the fan is in one piece).
WTF is it? it feels to me like driveshaft vibration. Should I index the driveshaft? Could a bad motor mount couse this?
