On some model of G35 wheels, the front and rear have different offsets (33mm and 30mm). Other models did not. You'd have to look inside the rim for the markings to be certain.SnakeHandler wrote:Do the 18X8 wheels on the G35 have the same backspacing and offset from front to back?I need to replace one and need to know if there is a difference between the front and rears.
Thanks for your help!!
Ah, yes. I forgot about that size being all the same offset for the G wheels ... sorry about that!audtatious wrote:The 18x8's should all have the same offset.
