G35 fuel filler door is stuck/locked
rbsaint
Car: 2003 G35
2003 G35 fuel filler door is stuck/locked. Have tried unlocking all doors, panic button, key in lock. Any ideas? Is there a manual method?
C-Kwik
Not sure on this one. You might want to ask the dealer.
joe603
Car: 2014 Durango R/T
Try putting a little pressure on the fuel door, while you tap the unlock button on your fob. You could have a weak spring in the door, not allowing it to open.
DragonG35
Car: 2007 G35 Coupe
This sounds lile an actuator problem. Had the same thing happen on my 03' Murano and they had to replace it. Was told it was a common problem. Iritating none the less.
2007 Dragon G35 GT-R
infinititech1
ok...unlock doors...and take a small flathead and pry out on the gas door...not hard tho...just to see if it will come out. you need a new actuator
Omegamerc
Car: 2008 G35xS
infinititech1 wrote:ok...unlock doors...and take a small flathead and pry out on the gas door...not hard tho...just to see if it will come out. you need a new actuator
I rather take it to the dealer, they make a nice gash on the paint job they pay for it.
smartbomb13
Car: 2003 g35 6mt
that happend to me. go into the trunk and just carefully bend the right side interior mats back on the right rear wheel well. there is a manual release for the filler door. i reset mine, and havent had aroblem since.
infinititech1
thats why ya use a towel or something..i've had to do it many times
smartbomb13
Car: 2003 g35 6mt
a towel for what?
infinititech1
to cover the screwdriver or whatever ur using...i've had to do it a few times to pop it open
smartbomb13
Car: 2003 g35 6mt
there is a button inside the trunk no screwdriver needed. what kind of tech are you, you should know that. hope you dont work at the dealership i go to!!!
joe603
actually, infinititech1 is one of the most knowledgeable guys on this site. You need a screwdriver to pop the cover if the actuator is stuck. Using the manual release will not do anything.
Look at some posts before you insult someone.
smartbomb13
Car: 2003 g35 6mt
what do you think the manual release is for? actually the button for the manual release pushes directly on the backside of the piston on the actuator. so either you dont know the button im talking about or your not strong enough to push it.
infinititech1
manual release won't work if its the spring stuck...but thanks anyway...and btw never messed up a car popping it open that way thank you
