chuckm »
https://forums.nicoclub.com/chuckm-u82307.html
Mon Nov 30, 2009 6:47 pm
Thanks to kind replies to my problem. Car now has ca. 174K (carefully driven, well-maintained) miles on the clock. A lot--but not so much for a good SR20DE. It still has good, even compression, burns no measurable oil in the 3K it gets between changes, will still go 80+ all day thru the mountains, quite happily, just as years ago--but, as said, with poorer mpg. Trust me, I've tried/checked everything cited anywhere in the FSM and found no emissions/ignition/fuel system part out of specs. Filters are recent (and old ones showed little sign of crud). Someone asked about plugs. I've had best luck with NGK Lasers. Tried Bosch (2-3 years ago) & Autolite platinum (this summer), but got poorer performance, so went back to NGKs. So, I'm still mystified. I did have trouble ca. 5 years ago with the PAIR system--which will mess you up. But replaced all those bits--and have re-checked them recently & found them still in good order & functioning. It's really weird. Car starts first time every time, idles evenly @ ca. 800, revs smartly, as it should, accelerates about as it did years ago, has no trouble at speed--just crappy mpg. And yes, I am aware of tire pressures, tire size, tread pattern, etc., as possible factors. These are not an issue.Well, thanks for trying. chuck
