RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Tue Nov 20, 2007 8:18 am
Have you tried pulling the codes from the ecu yourself. There is a diagnostic check screw on the back of the ecu. In the OP's case, he may have a bad ecu. It seems obvious that the injectors aren't firing for some reason and the ecu controls that parameter.
