Hi folks,
I did a thorough search on this ahead of time and found no definitive information.
Background information:
It was proven by SOHO motorsports that (at least in the 350z) even with VDC switched off from the factory button the ECU is not giving full control of the car (ECU pulling timing, stability control partially on, among other things). There are two ways of disabling VDC: the cheap and easy way and the RIGHT way. The drifters at the local track will pull the "grey plug" (located next to the master cylinder) which is a harness plug that goes to the ABS. Disabling ABS will also fully disable VDC. The gauge cluster thus turns into a christmas tree. Now onto the RIGHT way. In the 350z platform, one cuts the orange wire going into the Yaw sensor module and wire it to a switch. The VDC OFF and SLIP lights turn on but ABS stays on.
In the M35/M45 clearly hitting the VDC button still doesn't give you 100% control of the car (can't do donuts/burnouts on my 08 m35s). So my question to the M35/M45 knowledge gurus and geeks is this:
How do we fully disable it on the Y50 cars?
Thanks in advance
