I get the message when I have the scanner turned on while the engine is running, it provides a 'current state' message for a bunch of different items, that one jumped out because it seems to indicate an issue. However, I don't get any actual error codes showing. The rest of the stats are rolling numbers that unfortunately don't mean much to me.VStar650CL wrote: ↑Wed Mar 30, 2022 4:59 pmDTC stands for "Diagnostic Trouble Code" in OBD-speak. So let me get this straight, if you aren't getting codes, where is your "FUELSYS1 OL-FAULT" message coming from? If it's your scanner and there are no fault codes along with it, it might imply that your ECM is kicking offline. "Informational messages" like that vary from scanner to scanner, you'd have to check the scanner manual. I have seen ECM Relays cause issues like what you're describing, and low voltage at the ECM can cause it to drop out and become incommunicado. That's especially true on an early OBD-II like your Sentra that only uses the K-Line on the OBD port and not the CANbus.
I really appreciate your chiming in on that one. I don't think i would have ever gotten to a blocked cat causing receding vacuum. I'll check it out.VStar650CL wrote: ↑Sun Apr 03, 2022 8:41 pmDisappearing vacuum generally means only one thing, an exhaust blockage. Check your cat.
You're most welcome. The simplest way to verify it (although not necessarily easy on a rusty '04) is to remove the A/F (front O2) sensor so the engine can breathe a little through the hole. If all of a sudden the vacuum increases, one or both of the cats is clogged.
