rgregoryb »
https://forums.nicoclub.com/rgregoryb-u257908.html
Wed Nov 30, 2016 3:31 pm
OK Z32 Brain trust
My ecu gives me a code 42, fuel temp sensor, so far I have replaced the sensor, replaced the connector, checked the wire from the sensor to the ecu and it is good no breaks. I have also cleaned the ground wires for the fuel rail. Erased the codes on the ecu, drive the car (runs great) and still get a code 42 when checking the ECU.
1. The only other possibility is the ECU?
2. Does the car even need the fuel temp sensor because it is only used during initial start up, or do I misunderstand it's actual function?
