carllath wrote: fuel has alsogotten into crank case.
How did you determine this?
Are you getting a good, consistent spark?
Why was your regulator replaced? Did he even check fuel pressure? Did he check compression? Check for codes?
A torn injector O ring will likely not cause your car to not start.
