fuel pump
who's next
Car: Charmant with the heart of a nissan (CA18DET)
I would just like to know what's the minimum psi a fuel pump should be pushing to feed a ca18detthanks
c-rad
Car: 1991 Nissan 240SX w/CA18DET
who’s next wrote:I would just like to know what's the minimum psi a fuel pump should be pushing to feed a ca18detthanks
I think you mean what VOLUME. I am sure on a 'stock' CA a 140-150lph pump would work fine, but considering how cheap Walbro's are, you can get a 190lph or 255lph pump with install kit for $85-90.
who's next
the thing is i have in a pierburg pump (german) and its pushes 255l/hr. but its in the car about 2 yrs. i have a fuel gauge just before the fuel filter in the engine bay and it says 32 psi. so i wanted to know if that's enough or if the pump is starting to fail and not pushing the required fuel.
c-rad
The fuel pressure regulator might be the part that's failing. If the diaphragm is worn out, it can leak excessively and not hold pressure as well.
slownslurious
I don't remember the correct idle/engine off pressure, but check the factory service manual, it has it in there.
boost_boy
who’s next wrote:the thing is i have in a pierburg pump (german) and its pushes 255l/hr. but its in the car about 2 yrs. i have a fuel gauge just before the fuel filter in the engine bay and it says 32 psi. so i wanted to know if that's enough or if the pump is starting to fail and not pushing the required fuel.
Good enough!
Dee
who's next
thanks guys
DjLiquid
Car: 1988 Nissan Pulsar
another question... regaurding the walbro 255lph fuel pump. Which cars fit the Pulsar, does anyone know offhand? I heard the Z32's do but I have yet to see one of those en eBay
