evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Feb 04, 2009 11:21 am
lots to cover hereyou can should only have 1 pump, either mechanical or electric, nto both, pick one, if you run the electric you need a fuel pressure regulator, anything over 3psi will overpower the needles int he su carb's, and you shouldn't have to prime the fuel lines to start the car, the float bowls int he carbs should have enough fuel to get the car running as the pump begine to refill them
if you do a swap to the RB you'll need a high pressure electric ump, somethign capable of running 38-43 psi at idle and up to 90-100 psi at WOT, your FPR is boost referenced so the more boost you run the higher the fuel pressure, the size of the fuel pump will be determined by how much power you want to run, and of course ti has to be an external pump, the stokc 280Z n/a fuel pump is only good for 200 whp? the 280ZX Turbo pump is good for around 250 whp, I run an MSD pump wihich is good for around 500 hp
the stock tank is fine but the fuel lines are a bit small to feed a large aftermarket pump, I sumped my tank with a -8 a/n feed and added a -6 a/n return
