Fuel pump noise when priming!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I just noticed this a few days ago.... When I turn the ignition to ON (engine not running) the pump makes a loud HUUUUMMM.... It only happens when its cold and the first startup of the day.... As soon as I start the engine, i hear nothing but the normal sound of it (just a slight hiss when I open the trunk)....
THe pump has been replaced within the last 6000 or so miles (before I obtained it)..
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
It's just pressurizing the rails, overnight bleeds off the fuel pressure. I think you are getting too knowledgable and hearing trouble that isn't there. Kind of like when you took biology and imagined you had symptoms for all those rare diseases.
Q451990
The noise is always more obvious to me when it's cold too... Judging by the pic in your signature line I'm sure it's a little frosty in that gas tank in the mornings :D
As long as you don't hear it at idle you should be fine. I'd say a good replacement interval for the fuel pump in normal conditions would be 70-80K miles.
Heath
Q45tech
In winter the trimode [trispeed] pump/fpcu gets a longer wide open speed signal from ecu............function of a colder [to start] coolant temp sensor reading.
It appears that colder than 45-50F +- engages the extra time.
elwesso
2007 BMW M Coupe
Ok... Well Im glad this is normal.... I DONT wanna go through this fuel pump thing.....
Q45tech
Still it is NEVER normal to hear the pump running under any conditions!!!!!!!!!!!!!!!!
elwesso
2007 BMW M Coupe
Could my FPCU be semi-fried?? Apparently the pump died and the car had to be tansported to get fixed.... The car runs just fine....
Will the bad FPCU (but apparently works) kill the new pump?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:Still it is NEVER normal to hear the pump running under any conditions!!!!!!!!!!!!!!!!
Good! At least now I know that I am not totally deaf!
Q45tech
More pumps are prematurely destroyed by failure to buy clean gasoline and failure to clean out the tank when a pump is replaced.
Takes a few extra hours, if the tank is nearly empty, and jugs to hold the old gasoline and 2-3 gallons of new gasoline to get to the station to refill.
But new pumps almost always last at least 12,000 miles [most 40-60k] or a year so the repairer is off the hook if he doesn't force you to spend the extra money for tank removal and cleaning.
Why orginal pumps lasted 100k+ and replacements fail sooner.
mateo
I have read several articles about hissing caused by the fuel pump. I've noted a small hissing sound in my 93 J30 for about a year now (it currently has 178k miles - I drive about 15k a year).
I'm not sure if it is the fuel pump, or just a character of the J30. It occurrs at start-up but then dissipates within about a mile (at least I don't notice it by then). I notice it when the engine is cold; that is about the only time I drive it - to and from work. Its not loud. I also notice that the sound stops if I put the car in neutral shortly after driving down the driveway, then resumes for a few minutes after engaging Drive.
Any thoughts? J30 Character or a true problem?
VenCountyQ
My fuel pump has hummed when I turn the ignition to the ON position for 6 years now, so I guess it is just taking an extra long time to die.
Q45tech
We just removed an orginal 1992 Q fuel pump with 225,000 miles it was only supplying 15psi of pressure instead of 44 psi. But I guess you could say it was working -- kinda. Not much ability to accelerate and the ecu couldn't correct the fuel more than 20% so it ran really really really lean.
VenCountyQ
Good point regarding the possibility of reduced fuel pressure, I'm going to check mine with a gauge. Any good fuel pressure gauges you can recommend? Although having just replaced the knock sensors ( both were cracked at 150K ) and cleaning the throttle body my car is running faster than it ever has. Any additional speed would be icing on the cake.
And yes while replacing the knock sensors I replaced every hose under and around the plenum ( fuel, air, PCV, vacuum, brake booster, coolant, heater, purge canister, EGR, IACV ). We need Joe to come up with the plenum-plus hose kit. Although it will probably cost close to $1000.
96QQ45
Car: 2007 G35x
I finally got around to changing my fuel pump this weekend. It was humming away for quite some time and I was concerned that it was going to fry the controller and/or leave me stranded. Three hours on Saturday and I have peace of mind and no more humming.
I strongly recommend you get one from Joe and change it-easy project.
Eswift
Car: should be obvious enough
...unless it is a Ford truck.
Brand new, you can hear those fuel pumps from 100 ft.
mateo
I looked on-line for one from Joe - they are just over $200 bones! Yikes, I have other things to do before that. What am I out besides being inconvenienced, should the fuel pump go out before I get to it?
elwesso
2007 BMW M Coupe
FUEL PUMP MUST BE REPLACED ASAP!!! The only thing you could do is run the fuel pump control unit (500) and if it starts misfiring you could kill the cats ($more than you got)....
That is, if its bad.... Basically, if you have over 60k and it hasnt been done yet, its probably time...
Eswift
wes, I am pretty sure it is different for the J - a bad pump wont off your control unit.
Even if it did, it is a $5 junkyard part.
PS . pump is a bosch part, local parts depot will offer them at about $200 as well. (not implying that you shouldnt go with Joe, just that there is that option in case of an emergency.)
Eswift
also, there is no real risk to the cats here.
dying pump=lower fuel pressure=lean mixture if anything=not a real risk for the cats, which are harmed by unburnt fuel, oil, or coolant entering the exhaust.
pretty good closed-loop feedback with the lambda sensors anyway, and he will see poor engine performance far before cats are at risk.
Eswift
IN any case, i would check your fuel pressure before getting a new pump. if it is having trouble :getting it up:, i would then replace the pump in a timely fashion.
also check the function of your FPR...
elwesso
2007 BMW M Coupe
I am very sorry, being a Q owner I assume everything is for the Q, i didnt notice it was a J30.... IM sure its much different, as fuel pumps dont seem to have many problems on the J
