fuel pump location under rear seat?
95j30driver
Car: 1995 infiniti j30
Postby 95j30driver » Sun May 20, 2018 9:46 am
On my 95 j30 is the fuel pump access underneath my rear seat? Also does anyone know what size bolts they are if so? Thanks
macgiver
Re: fuel pump location under rear seat?
Postby macgiver » Sun May 20, 2018 8:02 pm
mac, No don't do anything w/rear seat. In trunk you remove the black carpeted "Baffle" retainers,peel back/remove baffle like you were getting at deck speakers under Rr. windshield glass. Gas tank with pump access ,easily accessible on top of tank is actually in this "trunk area".I believe nuts holding flange are 10mm and/or 12mm.
95j30driver
Postby 95j30driver » Mon May 21, 2018 2:18 am
So, in other words, you don't have to drop the tank to replace the pump then? That would be awesome.
macgiver
Postby macgiver » Mon May 21, 2018 8:41 am
mac, when you remove that trunk baffle everything your talking about is "before your eyes" , and if you can't pull that pump out of the top of the tank - better hire someone :lolling:
