Fuel pressure gauge/regulator
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
N-Dually
Car: 1986 Nissan 720 Dually
Hi,
I have been reading many articles on fuel pressure gauges and regulators. Seems like they are mostly junk. Does anyone have one that they have been using for a long time that is accurate and doesn't leak? I will be needing it for a Weber install.
Thanks.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I built one using a brass tee, some barbs and a Summit Racing gauge. I used pipe dope instead of the teflon tape. It's been on for a couple of months now with no leaks.
fastboatman29212
Car: left this forum. Sold my truck.
OK, I'm curious now. Why do you need a gauge or regulator? Does a Weber require a specific pressure range in order to operate correctly?
N-Dually
fastboatman29212 wrote:OK, I'm curious now. Why do you need a gauge or regulator? Does a Weber require a specific pressure range in order to operate correctly?
From what I have read a Weber requires 2.5 to 4 psi. I think I will start with just a gauge. I hope to get lucky and not need the regulator.
Oh, and thank you Reverend for the pics!
PEZi
Yep. 3.5 psi max on a Weber. Note it!
N-Dually
crap... I added a pressure gauge today (Spectre). 5.5 to 6 psi with just the pump on and not the truck. (coils off right now).
Off to TRY to find a descent regulator...
ThatsDifferent
Car: 1983 720 4x4
Reverend, where did you score that air cleaner? I've thought about a weber but didn't like my options for air cleaners. I was considering a Holley. Does it have a warm air intake for cold weather?
Rev_D21
TD, mine is not a Datsun, it's 95 Hardbody. I just like chilling with the Datsun truck guys and BSing. You might be able to adapt the cover to work on yours but bear in mind it's held on with two wing nuts, not just one.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
dually are your return lines hooked up? if not hook them up it might drop the pressure down to spec. If you can avoid using a regulator do so. Most of em are crap and it puts extra strain on the pump. i'd try running a decoupled loop before I used a regulator.
Return to “Datsun 720”
