MrFeesLaw »
https://forums.nicoclub.com/mrfeeslaw-u256297.html
Fri Feb 12, 2016 11:03 am
I would double check to make sure it is fuel in the tailpipe, and make sure it isn't just dripping on the pipe from somewhere else if it is fuel. If so, you likely have much bigger problems. The only way fuel gets to the exhaust would be for both combustion not occurring, AND a valve not closing properly. If you have a Catalytic converter on your car, and there is fuel in your exhaust, it is likely junk now as well.
Find out if it is FOR SURE fuel, and that it is FOR SURE, coming out of your engine and into the exhaust pipe. Then post your findings here. That will help narrow down the issue.
