NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Tue Nov 03, 2015 7:38 am
No, the rail, injectors, and lower plenum are all different for Phase 2, the only way to run phase 2 injectors in a phase 1 plenum is to use the phase 1 rail and injector adapter kit to fit the phase 2 injectors in the phase 1 rail. you could change out the lower plenum to a phase 2 but apparently the intake runners don't match the phase 1 heads. I've never confirmed this but IIRC that is the reason that no one swaps the plenum,that and its much easier to just install the adapters.
