evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Feb 13, 2010 8:29 am
I'm no expert on E85 but my understanding if it brings up these potential problems
my truck is flex fuel and I've run regular unleaded and e85 through it
your fuel milage drops with E85 as it contains fewer btu's and therefore requires more fuel to make the same amount of power, if memory serves it's approximately 30% more fuel, in my truck at the cost of e85 vs 87 octane 87 is much cheaper and e85 does rise in price with gas
here are some ceoncerns I have with the conversion:fuel lines, standard rubber hoses are nto compatible with E85, and there are a lot of little pieces of rubber hose on your fuel lines, by the tank, under the plenum, by the fuel filter etc
O rings, your stockO rings are nto compatible and would have to be changed to ones that are compatible
ignition timing, e85 has a much higher octane and therefore requires less ignition timing to run propperly
fuel mapping, as I states you need fuel maps matched to the E85
tuning I'm not sure on, as to if E85 is compatible wiht standard O2's or standard O2's on what the target ratio and voltage would be in either case
also E85 si far more conductive then gas so pump instalation might be an issue
