evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Sep 08, 2009 5:06 am
running rich has no effect on the fuel pump
the jsk fuel rail or any other fuel rail has zero effect on how rich ior lean your car runs, the larger rails have the capacity to supply mroe fuel, but unless you have the injectors and dutycycle to use them you won't get any extra fuel
the afm has a plastic cap, take that off, thats where yiou adjust the preload ont he spring, thsi directly effects duty cycle to the injecotrs
yes you can use a Z31 ecu, yous need the L28ET distibutor and shaft, Z31 harness, ecu, mas, distributor shutter wheel and a couple fo other bits, sorry it's been a long time since I considdered that
280zx is non OBD, actually it's bosch L-Jetronic, the Z31 is OBD0, Z32 is oOBD1
the stock fuel pump runs ar the same speed no matter how much power you are making, the only thing you can do to hurt the fuel pump in a stock configuraion is to use an AFPR to raise the static fuelo presure, putting more strain on the pump, Z32 pumps are in tank, the S130 uses and extranal pump, so no you can't swap a Z32 pump in
do nto waste you time wiht these pigy bakc or fuel controller box's, if you want mroe control over the computer, either run megasquirt or the Z31 ecu swap with a zemulator or similar
